Ana içeriğe geç
Panasonic D-snap SV-AV50 Screen Replacement
Neye ihtiyacın var
  1. Panasonic D-snap SV-AV50 Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Open and rotate the screen, then remove the screw(3.5mm Philips) indicated with a screwdriver.
    • Then, rotate the screen 180 degrees and remove the screw on the opposite side.
  2. Panasonic D-snap SV-AV50 Screen Replacement: adım 2, 1 resimden 1.
    • Remove the screw(2.6mm Philips) indicated on the top of the screen with the screwdriver. Then remove the corresponding screw on the bottom of the screen.
  3. Panasonic D-snap SV-AV50 Screen Replacement: adım 3, 1 resimden 1.
    • Pull the backing away from the screen as shown in the photo.
  4. Panasonic D-snap SV-AV50 Screen Replacement: adım 4, 1 resimden 1.
    • Unplug the black connector between the camera and the screen by pulling down.
    • For increased ease, use tweezers or forceps, as seen in the picture
  5. Panasonic D-snap SV-AV50 Screen Replacement: adım 5, 1 resimden 1.
    • Pull the screen away from the camera the same way that you removed the screen backing.
  6. Panasonic D-snap SV-AV50 Screen Replacement: adım 6, 1 resimden 1.
    • Use the screwdriver to remove the screw(2.46mm Philips) indicated.
  7. Panasonic D-snap SV-AV50 Screen Replacement: adım 7, 1 resimden 1.
    • Pull upwards on the screen border to remove it from the actual screen.
Sonuç
Zoe Hinck
29 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-19, Amido Spring 2012 Cal Poly, Team 6-19, Amido Spring 2012 üyesi
CPSU-AMIDO-S12S6G19
3 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
I need the LCD screen, can you helpme?
leon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 1,060
