Ana içeriğe geç
Panasonic DECT 6.0 Button Replacement
Neye ihtiyacın var
  1. Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: adım 1, 3 resimden 1. Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: adım 1, 3 resimden 2. Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: adım 1, 3 resimden 3.
    • Remove the battery cover by pushing the tab upwards and sliding it off.
    • Pull out the battery/energy source from its slot.
    • Keep all pieces in a safe and orderly manner for ease of reassembly.
  2. Panasonic DECT  6.0 Button Replacement: adım 2, 3 resimden 1. Panasonic DECT  6.0 Button Replacement: adım 2, 3 resimden 2. Panasonic DECT  6.0 Button Replacement: adım 2, 3 resimden 3.
    • Unscrew the screws you see on the inside of the casing using an appropriate screwdriver from the JIS Driver Set.
    • Carefully pry each side open with the iFixit Opening tool.
    • Detach the back of the phone case.
  3. Panasonic DECT  6.0 Button Replacement: adım 3, 3 resimden 1. Panasonic DECT  6.0 Button Replacement: adım 3, 3 resimden 2. Panasonic DECT  6.0 Button Replacement: adım 3, 3 resimden 3.
    • Unscrew the screws to remove the motherboard using an appropriate screwdriver from the JIS Driver Set.
    • Potential for device damage
  4. Panasonic DECT  6.0 Button Replacement: adım 4, 3 resimden 1. Panasonic DECT  6.0 Button Replacement: adım 4, 3 resimden 2. Panasonic DECT  6.0 Button Replacement: adım 4, 3 resimden 3.
    • Carefully pull off the circuitry and cords from the front half of the phone and set them aside.
    • Bring the buttons to the front.
  5. Panasonic DECT  6.0 Button Replacement: adım 5, 2 resimden 1. Panasonic DECT  6.0 Button Replacement: adım 5, 2 resimden 2.
    • Pull gently to separate the button pad from the phone cover.
    • Identify the broken/jammed button you were having issues with.
    • Replace or return the button to its function.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jacob
131 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 516
