Ana içeriğe geç
Panasonic DMC-FZ35 Top Control Panel Replacement
Neye ihtiyacın var
  1. Panasonic DMC-FZ35 Top Control Panel Replacement, Clear compartment: adım 1, 1 resimden 1.
    • Remove the battery and memory card from the unit.
  2. Panasonic DMC-FZ35 Top Control Panel Replacement, Remove side screws: adım 2, 2 resimden 1. Panasonic DMC-FZ35 Top Control Panel Replacement, Remove side screws: adım 2, 2 resimden 2.
    • Remove 1 screw (0.4mm) from left side of unit
    • Remove 1 screw (0.4mm) from right side of unit near Strap bar.
    • Remove 1 screw (0.6mm) from right side of unit next to usb door
  3. Panasonic DMC-FZ35 Top Control Panel Replacement, Remove Screws from Bottom: adım 3, 1 resimden 1.
    • Remove 3 Screws from bottom of unit
    • Remove 2 (0.6mm) screws next to door
    • Remove 1 (0.4mm) screw opposite of door
  4. Panasonic DMC-FZ35 Top Control Panel Replacement, Remove top screw: adım 4, 1 resimden 1.
    • Raise the Pop-Up flash by pushing the flash button.
    • Remove the screw (0.6mm) from underneath the flash assembly.
  5. Panasonic DMC-FZ35 Top Control Panel Replacement, Accessing the flex cables: adım 5, 2 resimden 1. Panasonic DMC-FZ35 Top Control Panel Replacement, Accessing the flex cables: adım 5, 2 resimden 2.
    • Please be careful. Do not lift the cover fully because it is still attached to the Main Board via flex cables.
    • Lift the cover slightly as shown in picture # 1
    • Tilt the back cover as shown in picture #2. Be careful because the flex cables are still attached.
  6. Panasonic DMC-FZ35 Top Control Panel Replacement, Release the Flex cables: adım 6, 3 resimden 1. Panasonic DMC-FZ35 Top Control Panel Replacement, Release the Flex cables: adım 6, 3 resimden 2. Panasonic DMC-FZ35 Top Control Panel Replacement, Release the Flex cables: adım 6, 3 resimden 3.
    • Flip up LCD cable clamp with a spudger or other tool.
    • Flip up backlite cable clamp with a spudger or other tool
    • Removal of the mic wire is optional. My suggestion is to leave it attached. The mic can get damaged if you pull on the wire.
  7. Panasonic DMC-FZ35 Top Control Panel Replacement, Remove the mic: adım 7, 3 resimden 1. Panasonic DMC-FZ35 Top Control Panel Replacement, Remove the mic: adım 7, 3 resimden 2. Panasonic DMC-FZ35 Top Control Panel Replacement, Remove the mic: adım 7, 3 resimden 3.
    • Remove the 2 screws (0.4mm) that are holding the mic assembly
    • Next step (shown in picture #2) remove the metal mic hold part.
    • Next step (shown in picture #3) use a spudger to pry off the mic. Careful not to damage the wiring.
  8. Panasonic DMC-FZ35 Top Control Panel Replacement, Remove the LCD: adım 8, 3 resimden 1. Panasonic DMC-FZ35 Top Control Panel Replacement, Remove the LCD: adım 8, 3 resimden 2. Panasonic DMC-FZ35 Top Control Panel Replacement, Remove the LCD: adım 8, 3 resimden 3.
    • Release the hold clips that hold the LCD retainer in place.
    • Remove the LCD metal retainer plate as shown in picture #2
    • Remove the LCD as shown in picture # 3
  9. Panasonic DMC-FZ35 Top Control Panel Replacement, Swap out Old LCD: adım 9, 1 resimden 1.
    • Swap out your old LCD with the new one.
    • If your backlite is ok you can buy only the LCD Display. But it is easier to purchase the LCD with the backlite attached. Replacement LCD Display VYQ5034
  10. Panasonic DMC-FZ35 Top Control Panel Replacement, Release the Main PCB Flex Cables: adım 10, 3 resimden 1. Panasonic DMC-FZ35 Top Control Panel Replacement, Release the Main PCB Flex Cables: adım 10, 3 resimden 2. Panasonic DMC-FZ35 Top Control Panel Replacement, Release the Main PCB Flex Cables: adım 10, 3 resimden 3.
    • Pull the 3 flex cables out using flat needle nose pliers (it is easier to slide open the black clamps prior to pulling). These are sliding clamps not flip (up) clamps.
    • Pull the single cable from the socket. This is a friction fit socket.
    • Flip up the Cable clamp (picture #2) using a spudger as shown in the previous pages and release the cable.
    • Flip up the Cable Clamp (picture #3) using a spudger and release the cable.
  11. Panasonic DMC-FZ35 Top Control Panel Replacement, Releasing wire: adım 11, 3 resimden 1. Panasonic DMC-FZ35 Top Control Panel Replacement, Releasing wire: adım 11, 3 resimden 2. Panasonic DMC-FZ35 Top Control Panel Replacement, Releasing wire: adım 11, 3 resimden 3.
    • Release the socket. It would be best to use a method that does not require pulling on the wires.
    • One way to release the socket is by carefully inserting a thin wedge between the male and female sockets and carefully pry them apart.
    • If you are using a sharp object be careful around the wires. Any slip can cut the wires. To prevent any ESD damage please do not touch any part of your circuit board with your bare hands or tools. Use nitrile gloves or an esd device.
    • Remove 1 silver screw (0.4mm) next to joy stick.
    • Remove 1 silver blue tip coated (0.4mm) screw bottom left corner.
  12. Panasonic DMC-FZ35 Top Control Panel Replacement, 0.8mm screws: adım 12, 1 resimden 1.
    • Remove 2 silver (0.8mm) screws
  13. Panasonic DMC-FZ35 Top Control Panel Replacement: adım 13, 3 resimden 1. Panasonic DMC-FZ35 Top Control Panel Replacement: adım 13, 3 resimden 2. Panasonic DMC-FZ35 Top Control Panel Replacement: adım 13, 3 resimden 3.
    • Open battery compartment
    • Grab battery door and lift up (do not remove yet) the Main Board and Compartment Part
    • Carefully flip over board and pull up so that the flash assembly rises along with the main board from the camera body. Remove entire assembly from the camera body.
  14. Panasonic DMC-FZ35 Top Control Panel Replacement: adım 14, 3 resimden 1. Panasonic DMC-FZ35 Top Control Panel Replacement: adım 14, 3 resimden 2. Panasonic DMC-FZ35 Top Control Panel Replacement: adım 14, 3 resimden 3.
    • Release the two cables from the main board.
    • Used spudger to flip up cable clamp and remove flex cable
    • Release the two hold clips and remove battery compartment
  15. Panasonic DMC-FZ35 Top Control Panel Replacement: adım 15, 1 resimden 1.
    • Swap out your old Board
  16. Panasonic DMC-FZ35 Top Control Panel Replacement, Top Control Panel: adım 16, 3 resimden 1. Panasonic DMC-FZ35 Top Control Panel Replacement, Top Control Panel: adım 16, 3 resimden 2. Panasonic DMC-FZ35 Top Control Panel Replacement, Top Control Panel: adım 16, 3 resimden 3.
    • Pull out Top control panel from camera body
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sales Cameraparts4you
3.251 İtibar
20 adet Kılavuz yazıldı
2Kılavuz Yorumları
Is it possible to remove the Top control panel without removing the main PCB ?
Matthew Johnston - Yanıt
Required parts no longer for sale
Alex Denstore - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 1,135
