Ana içeriğe geç
Panasonic DMC-FZ70 LCD Screen Replacement
Neye ihtiyacın var
  1. Panasonic DMC-FZ70 LCD Screen Replacement, Back Panel: adım 1, 2 resimden 1. Panasonic DMC-FZ70 LCD Screen Replacement, Back Panel: adım 1, 2 resimden 2.
    • All screws should be removed using a Phillips #0 screwdriver.
    • Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
  2. Panasonic DMC-FZ70 LCD Screen Replacement: adım 2, 2 resimden 1. Panasonic DMC-FZ70 LCD Screen Replacement: adım 2, 2 resimden 2.
    • Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
  3. Panasonic DMC-FZ70 LCD Screen Replacement: adım 3, 2 resimden 1. Panasonic DMC-FZ70 LCD Screen Replacement: adım 3, 2 resimden 2.
    • Turn the camera upside down and unscrew the three 5mm screws found on the bottom.
  4. Panasonic DMC-FZ70 LCD Screen Replacement: adım 4, 2 resimden 1. Panasonic DMC-FZ70 LCD Screen Replacement: adım 4, 2 resimden 2.
    • On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
    • With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
  5. Panasonic DMC-FZ70 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Proceed to remove the four 5mm Phillips screws that you just uncovered.
  6. Panasonic DMC-FZ70 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Slowly pull on both side of the camera, until both halves begin to separate from each other.
    • Do not pull too hard, as both halves are held together with ZIF connector cables.
  7. Panasonic DMC-FZ70 LCD Screen Replacement: adım 7, 3 resimden 1. Panasonic DMC-FZ70 LCD Screen Replacement: adım 7, 3 resimden 2. Panasonic DMC-FZ70 LCD Screen Replacement: adım 7, 3 resimden 3.
    • Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
    • Carefully pull the ribbon cables out of the slot once they have been released.
    • Only the two indicated connectors need to be removed to separate the two halves of the camera.
  8. Panasonic DMC-FZ70 LCD Screen Replacement, LCD Screen: adım 8, 2 resimden 1. Panasonic DMC-FZ70 LCD Screen Replacement, LCD Screen: adım 8, 2 resimden 2.
    • Unscrew the five 5mm screws on the panel that you just removed.
  9. Panasonic DMC-FZ70 LCD Screen Replacement: adım 9, 2 resimden 1. Panasonic DMC-FZ70 LCD Screen Replacement: adım 9, 2 resimden 2.
    • Remove the entire silver panel to reveal the back of the LCD screen
  10. Panasonic DMC-FZ70 LCD Screen Replacement: adım 10, 1 resimden 1.
    • Remove the LCD screen.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Alberto Rodriguez
531 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-3, Maness Winter 2017 Cal Poly, Team 21-3, Maness Winter 2017 üyesi
CPSU-MANESS-W17S21G3
6 Üyeler
12 adet Kılavuz yazıldı
5Kılavuz Yorumları
Where can I find the screen to replace the one that is cracked?
tim krikston - Yanıt
i am not able to find the new display where-in they could ship it to INDIA
if u find any please mail me - ppavanshetty@gmail.com
Ppavan Shetty - Yanıt
After replacement the camera won't work, turn on but it doesn't work.
Harold De La Matta - Yanıt
After the LCD replacement my camera turn on but it doesn't work. Any ideas?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 30
Her zaman: 2,756
