Ana içeriğe geç
Panasonic DMC-FZ70 Motherboard Replacement
Neye ihtiyacın var
    1. Panasonic DMC-FZ70 Motherboard Replacement, Back Panel: adım 1, 2 resimden 1. Panasonic DMC-FZ70 Motherboard Replacement, Back Panel: adım 1, 2 resimden 2.
      • All screws should be removed using a Phillips #0 screwdriver.
      • Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
      FixBot'a Sor
      Yorum Ekle
    2. Panasonic DMC-FZ70 Motherboard Replacement: adım 2, 2 resimden 1. Panasonic DMC-FZ70 Motherboard Replacement: adım 2, 2 resimden 2.
      • Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
      FixBot'a Sor
      Yorum Ekle
    3. Panasonic DMC-FZ70 Motherboard Replacement: adım 3, 2 resimden 1. Panasonic DMC-FZ70 Motherboard Replacement: adım 3, 2 resimden 2.
      • Turn the camera upside down and unscrew the three 5mm screws found on the bottom.
      FixBot'a Sor
      Yorum Ekle
    4. Panasonic DMC-FZ70 Motherboard Replacement: adım 4, 2 resimden 1. Panasonic DMC-FZ70 Motherboard Replacement: adım 4, 2 resimden 2.
      • On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
      • With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
      FixBot'a Sor
      Yorum Ekle
    5. Panasonic DMC-FZ70 Motherboard Replacement: adım 5, 1 resimden 1.
      • Proceed to remove the four 5mm Phillips screws that you just uncovered.
      FixBot'a Sor
      Yorum Ekle
    6. Panasonic DMC-FZ70 Motherboard Replacement: adım 6, 1 resimden 1.
      • Slowly pull on both side of the camera, until both halves begin to separate from each other.
      • Do not pull too hard, as both halves are held together with ZIF connector cables.
      FixBot'a Sor
      Yorum Ekle
    7. Panasonic DMC-FZ70 Motherboard Replacement: adım 7, 3 resimden 1. Panasonic DMC-FZ70 Motherboard Replacement: adım 7, 3 resimden 2. Panasonic DMC-FZ70 Motherboard Replacement: adım 7, 3 resimden 3.
      • Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
      • Carefully pull the ribbon cables out of the slot once they have been released.
      • Only the two indicated connectors need to be removed to separate the two halves of the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Panasonic DMC-FZ70 Motherboard Replacement, Motherboard: adım 8, 1 resimden 1.
      • Using a Torx driver, unscrew the two 5mm Phillipd screws on the motherboard
      FixBot'a Sor
      Yorum Ekle
    2. Panasonic DMC-FZ70 Motherboard Replacement: adım 9, 3 resimden 1. Panasonic DMC-FZ70 Motherboard Replacement: adım 9, 3 resimden 2. Panasonic DMC-FZ70 Motherboard Replacement: adım 9, 3 resimden 3.
      • The five ribbon cables shown will need to be removed from the ZIF connectors. Using a plastic opening tool, unlock the cables by lifting the black strip on the rectangular connection socket.
      • Carefully pull each of the ribbon cables out of their sockets.
      • The cable should slide out smoothly- any significant resistance might signal that the locking lever has not yet released the cable.
      FixBot'a Sor
      Yorum Ekle
    3. Panasonic DMC-FZ70 Motherboard Replacement: adım 10, 2 resimden 1. Panasonic DMC-FZ70 Motherboard Replacement: adım 10, 2 resimden 2.
      • Once the screws and the ribbon cables have been removed, lift the mother board from its slot.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Emily Kuzmicky
469 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-3, Maness Winter 2017 Cal Poly, Team 21-3, Maness Winter 2017 üyesi
CPSU-MANESS-W17S21G3
6 Üyeler
48 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 41
Her zaman: 2,425
