Giriş
This guide will help removed and replaced your damaged or old motherboard. If you have problems turning on your camera and you have checked your battery then you may need to follow this guide to replace the motherboard. Before you begin, make sure that the battery and SD card have been removed.
Neye ihtiyacın var
Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
Using a Torx driver, unscrew the two 5mm Phillipd screws on the motherboard
3 farklı kişi bu kılavuzu tamamladı.
