Ana içeriğe geç
Panasonic DMP-BD89 Disk Drive Replacement
Neye ihtiyacın var
  1. Panasonic DMP-BD89 Disk Drive Replacement, Disk Tray Cover: adım 1, 2 resimden 1. Panasonic DMP-BD89 Disk Drive Replacement, Disk Tray Cover: adım 1, 2 resimden 2.
    • First, before powering off, press the eject button to open the tray.
    FixBot'a Sor
    Yorum Ekle
  2. Panasonic DMP-BD89 Disk Drive Replacement: adım 2, 3 resimden 1. Panasonic DMP-BD89 Disk Drive Replacement: adım 2, 3 resimden 2. Panasonic DMP-BD89 Disk Drive Replacement: adım 2, 3 resimden 3.
    • Remove the front cover of the tray.
    • Do so by gently pushing it out, away from the player, ensuring the pictured tabs clear the tray.
    • Then slide it vertically up and away.
    FixBot'a Sor
    Yorum Ekle
  3. Panasonic DMP-BD89 Disk Drive Replacement: adım 3, 2 resimden 1. Panasonic DMP-BD89 Disk Drive Replacement: adım 3, 2 resimden 2.
    • Press eject button to close the tray.
    • Make sure to unpower and unplug device before continue work on other fixes.
    FixBot'a Sor
    Yorum Ekle
  4. Panasonic DMP-BD89 Disk Drive Replacement, Exterior Cover: adım 4, 2 resimden 1. Panasonic DMP-BD89 Disk Drive Replacement, Exterior Cover: adım 4, 2 resimden 2.
    • Using a Phillips #1 screwdriver, unscrew the back three screws.
    FixBot'a Sor
    Yorum Ekle
  5. Panasonic DMP-BD89 Disk Drive Replacement: adım 5, 1 resimden 1.
    • Slide the top panel horizontally to remove it.
    FixBot'a Sor
    Yorum Ekle
  6. Panasonic DMP-BD89 Disk Drive Replacement: adım 6, 3 resimden 1. Panasonic DMP-BD89 Disk Drive Replacement: adım 6, 3 resimden 2. Panasonic DMP-BD89 Disk Drive Replacement: adım 6, 3 resimden 3.
    • Locate 6 tabs across the device.
    • 2 are on the bottom, 1 is on the left and right, and 2 are are on the inside.
    FixBot'a Sor
    Yorum Ekle
  7. Panasonic DMP-BD89 Disk Drive Replacement: adım 7, 1 resimden 1.
    • Pop the 6 markers out.
    • Then take off the cover.
    FixBot'a Sor
    Yorum Ekle
  8. Panasonic DMP-BD89 Disk Drive Replacement, Disk Drive: adım 8, 2 resimden 1. Panasonic DMP-BD89 Disk Drive Replacement, Disk Drive: adım 8, 2 resimden 2.
    • Remove screws surrounding disk drive that attach it to outer cover.
    FixBot'a Sor
    Yorum Ekle
  9. Panasonic DMP-BD89 Disk Drive Replacement: adım 9, 2 resimden 1. Panasonic DMP-BD89 Disk Drive Replacement: adım 9, 2 resimden 2.
    • Remove the one green andthree blue tabs pictured that connect the disk drive to the board. Try to do so carefully, to avoid damage to the hardware.
    FixBot'a Sor
    Yorum Ekle
  10. Panasonic DMP-BD89 Disk Drive Replacement: adım 10, 1 resimden 1.
    • Carefully take the drive out of the device. Note where the feet need to go back in for reassembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Ensure the feet of the disk drive go back in the holes.
Julian
113 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 10
Son 30 gün: 35
Her zaman: 1,520
