Ana içeriğe geç
Panasonic DMP-BD89 Exterior Cover Replacement
Neye ihtiyacın var
  1. Panasonic DMP-BD89 Exterior Cover Replacement, Disk Tray Cover: adım 1, 2 resimden 1. Panasonic DMP-BD89 Exterior Cover Replacement, Disk Tray Cover: adım 1, 2 resimden 2.
    • First, before powering off, press the eject button to open the tray.
  2. Panasonic DMP-BD89 Exterior Cover Replacement: adım 2, 3 resimden 1. Panasonic DMP-BD89 Exterior Cover Replacement: adım 2, 3 resimden 2. Panasonic DMP-BD89 Exterior Cover Replacement: adım 2, 3 resimden 3.
    • Remove the front cover of the tray.
    • Do so by gently pushing it out, away from the player, ensuring the pictured tabs clear the tray.
    • Then slide it vertically up and away.
  3. Panasonic DMP-BD89 Exterior Cover Replacement: adım 3, 2 resimden 1. Panasonic DMP-BD89 Exterior Cover Replacement: adım 3, 2 resimden 2.
    • Press eject button to close the tray.
    • Make sure to unpower and unplug device before continue work on other fixes.
  4. Panasonic DMP-BD89 Exterior Cover Replacement, Exterior Cover: adım 4, 2 resimden 1. Panasonic DMP-BD89 Exterior Cover Replacement, Exterior Cover: adım 4, 2 resimden 2.
    • Using a Phillips #1 screwdriver, unscrew the back three screws.
  5. Panasonic DMP-BD89 Exterior Cover Replacement: adım 5, 1 resimden 1.
    • Slide the top panel horizontally to remove it.
  6. Panasonic DMP-BD89 Exterior Cover Replacement: adım 6, 3 resimden 1. Panasonic DMP-BD89 Exterior Cover Replacement: adım 6, 3 resimden 2. Panasonic DMP-BD89 Exterior Cover Replacement: adım 6, 3 resimden 3.
    • Locate 6 tabs across the device.
    • 2 are on the bottom, 1 is on the left and right, and 2 are are on the inside.
  7. Panasonic DMP-BD89 Exterior Cover Replacement: adım 7, 1 resimden 1.
    • Pop the 6 markers out.
    • Then take off the cover.
Sonuç
David Sun
213 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 267
