Ana içeriğe geç
Panasonic DVD-RV31 Player Disc Retainer Replacement
Neye ihtiyacın var
  1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Disk Tray Cover: adım 1, 1 resimden 1.
    • Eject the disk tray from the DVD player before removing power supply.
    FixBot'a Sor
  2. Panasonic DVD-RV31 Player Disc Retainer Replacement: adım 2, 1 resimden 1.
    • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
    FixBot'a Sor
  3. Panasonic DVD-RV31 Player Disc Retainer Replacement, Outer Case: adım 3, 2 resimden 1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Outer Case: adım 3, 2 resimden 2.
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
    FixBot'a Sor
  4. Panasonic DVD-RV31 Player Disc Retainer Replacement: adım 4, 1 resimden 1.
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
    FixBot'a Sor
  5. Panasonic DVD-RV31 Player Disc Retainer Replacement, Front Panel: adım 5, 2 resimden 1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Front Panel: adım 5, 2 resimden 2.
    • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
    FixBot'a Sor
  6. Panasonic DVD-RV31 Player Disc Retainer Replacement, Disk Drive: adım 6, 3 resimden 1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Disk Drive: adım 6, 3 resimden 2. Panasonic DVD-RV31 Player Disc Retainer Replacement, Disk Drive: adım 6, 3 resimden 3.
    • Locate the four screws securing the disk drive assembly. There are two on each side.
    • Use a narrow screwdriver to remove all four screws.
    • Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
    FixBot'a Sor
  7. Panasonic DVD-RV31 Player Disc Retainer Replacement: adım 7, 1 resimden 1.
    • Lift assembly by the front to pull metal bracket from the power board.
    • Pull up back end and lift drive out.
    FixBot'a Sor
  8. Panasonic DVD-RV31 Player Disc Retainer Replacement: adım 8, 1 resimden 1.
    • With the drive assembly separate from the player, hold as shown and pull the bracket edges away from the disk drive.
    • Lift bracket off and reserve for re-assembly.
    FixBot'a Sor
  9. Panasonic DVD-RV31 Player Disc Retainer Replacement, Disc Retainer: adım 9, 3 resimden 1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Disc Retainer: adım 9, 3 resimden 2. Panasonic DVD-RV31 Player Disc Retainer Replacement, Disc Retainer: adım 9, 3 resimden 3.
    • Grasp the bridge above the wheel and push the tabs on the side as shown.
    • Pull down firmly and away from the laser housing.
    FixBot'a Sor
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kevin
375 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-20, Garner Spring 2011 Cal Poly, Team 18-20, Garner Spring 2011 üyesi
CPSU-GARNER-S11S18G20
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 58
Her zaman: 5,824
