Ana içeriğe geç
Panasonic DVD-RV31 Player Left Control Board Replacement
Neye ihtiyacın var
  1. Panasonic DVD-RV31 Player Left Control Board Replacement, Outer Case: adım 1, 2 resimden 1. Panasonic DVD-RV31 Player Left Control Board Replacement, Outer Case: adım 1, 2 resimden 2.
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
    FixBot'a Sor
    Yorum Ekle
  2. Panasonic DVD-RV31 Player Left Control Board Replacement: adım 2, 1 resimden 1.
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
    FixBot'a Sor
    Yorum Ekle
  3. Panasonic DVD-RV31 Player Left Control Board Replacement, Front Panel: adım 3, 2 resimden 1. Panasonic DVD-RV31 Player Left Control Board Replacement, Front Panel: adım 3, 2 resimden 2.
    • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
    FixBot'a Sor
    Yorum Ekle
  4. Panasonic DVD-RV31 Player Left Control Board Replacement, Left Control Board: adım 4, 2 resimden 1. Panasonic DVD-RV31 Player Left Control Board Replacement, Left Control Board: adım 4, 2 resimden 2.
    • Grip jogger dial and lift up. It should come off easily.
    FixBot'a Sor
    Yorum Ekle
  5. Panasonic DVD-RV31 Player Left Control Board Replacement: adım 5, 3 resimden 1. Panasonic DVD-RV31 Player Left Control Board Replacement: adım 5, 3 resimden 2. Panasonic DVD-RV31 Player Left Control Board Replacement: adım 5, 3 resimden 3.
    • Remove 4 mounting screws as shown.
    • Unscrew and save brass tab.
    • Push in 2 plastic retainers and lift out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Kevin
375 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-20, Garner Spring 2011 Cal Poly, Team 18-20, Garner Spring 2011 üyesi
CPSU-GARNER-S11S18G20
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 2,452
