Ana içeriğe geç
Panasonic ER-GN30-K Motor Replacement
Neye ihtiyacın var
  1. Panasonic ER-GN30-K Motor Replacement, Motor: adım 1, 1 resimden 1.
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Motor Replacement: adım 2, 1 resimden 1.
    • Remove the back battery cap from the device by twisting it to the unlock position and pulling.
  3. Panasonic ER-GN30-K Motor Replacement: adım 3, 1 resimden 1.
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  4. Panasonic ER-GN30-K Motor Replacement: adım 4, 1 resimden 1.
    • Use a metal spudger to pry apart the silver plastic case.
    • Pull each side of the plastic case off.
  5. Panasonic ER-GN30-K Motor Replacement: adım 5, 1 resimden 1.
    • Unscrew one 20mm Phillips #00 screw.
  6. Panasonic ER-GN30-K Motor Replacement: adım 6, 1 resimden 1.
    • Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
  7. Panasonic ER-GN30-K Motor Replacement: adım 7, 2 resimden 1. Panasonic ER-GN30-K Motor Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a pair of tweezers to remove the plastic cover of the motor shaft by pulling it away from the motor.
  8. Panasonic ER-GN30-K Motor Replacement: adım 8, 1 resimden 1.
    • Remove the motor from the case by sliding the cover off of it.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Corey Tappan
209 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 15-3, Blackwell Fall 2015 USF Tampa, Team 15-3, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S15G3
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
My motor working intermittently. Took apart per instruction (very detailed, thank you). Everything loos good on the internals. I think my problem is succumb build up on the negative spring where it makes contact on negative end of battery. I scrapped it a little with tip of knife, working some what better. Need to find small wire brush to get in there and give it a good cleaning. Thank you for your guide :)
Rocko the fixit cat - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 39
Her zaman: 3,561
