Ana içeriğe geç
Panasonic ER-GN30-K Motor Shaft Replacement
Neye ihtiyacın var
  1. Panasonic ER-GN30-K Motor Shaft Replacement, Motor Shaft: adım 1, 1 resimden 1.
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Motor Shaft Replacement: adım 2, 1 resimden 1.
    • Remove the back battery cap from the device by twisting it to the unlock position and pulling.
  3. Panasonic ER-GN30-K Motor Shaft Replacement: adım 3, 1 resimden 1.
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  4. Panasonic ER-GN30-K Motor Shaft Replacement: adım 4, 1 resimden 1.
    • The motor shaft should be sticking out from the top of the device.
    • Use the metal prying tool to pry apart the silver plastic case .
    • Pull each side of the plastic case off.
  5. Panasonic ER-GN30-K Motor Shaft Replacement: adım 5, 1 resimden 1.
    • Unscrew one 20mm Phillips #00 screw.
  6. Panasonic ER-GN30-K Motor Shaft Replacement: adım 6, 1 resimden 1.
    • Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
  7. Panasonic ER-GN30-K Motor Shaft Replacement: adım 7, 2 resimden 1. Panasonic ER-GN30-K Motor Shaft Replacement: adım 7, 2 resimden 2.
    • Use a pair of tweezers to remove the plastic cover of the motor shaft by pulling it away from the motor.
Sonuç
Alejandro Garabatos
330 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-3, Blackwell Fall 2015 USF Tampa, Team 15-3, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S15G3
4 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
Thank you, small parts where switch is could be shown as well. Would be very helpful.
Advise for putting things back together: remove plastic switch cover and put back only after full reassembly
Aurimas Miko - Yanıt
Dear Alejandro,
thank You for your instruction, my question is where this motor shaft part is available? I can’t find it anywhere on the net. Thanks if you can help. Bence Fazekas
fazebence - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 1,567
