Ana içeriğe geç
Panasonic ES-RF31 Battery Replacement
Neye ihtiyacın var
  1. Panasonic ES-RF31 Battery Replacement, Battery: adım 1, 3 resimden 1. Panasonic ES-RF31 Battery Replacement, Battery: adım 1, 3 resimden 2. Panasonic ES-RF31 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Loose the screw at the bottom part of the razor
  2. Panasonic ES-RF31 Battery Replacement, Removing the Backcover: adım 2, 3 resimden 1. Panasonic ES-RF31 Battery Replacement, Removing the Backcover: adım 2, 3 resimden 2. Panasonic ES-RF31 Battery Replacement, Removing the Backcover: adım 2, 3 resimden 3.
    • Slide the cover from top to bottom
  3. Panasonic ES-RF31 Battery Replacement, Removing the Batterycover: adım 3, 2 resimden 1. Panasonic ES-RF31 Battery Replacement, Removing the Batterycover: adım 3, 2 resimden 2.
    • Loosen these eight screws
  4. Panasonic ES-RF31 Battery Replacement, Removing the Battery Cover: adım 4, 2 resimden 1. Panasonic ES-RF31 Battery Replacement, Removing the Battery Cover: adım 4, 2 resimden 2.
    • Insert an opening tool into the gap
    • Gently remove the battery cover
  5. Panasonic ES-RF31 Battery Replacement, Removing the Battery: adım 5, 2 resimden 1. Panasonic ES-RF31 Battery Replacement, Removing the Battery: adım 5, 2 resimden 2.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Daniel
934 İtibar
2 adet Kılavuz yazıldı
Ekip
iFixit EU Team iFixit EU Team üyesi
Staff
44 Üyeler
1.110 adet Kılavuz yazıldı
4 Yorum
Thanks Daniel,
I followed your instructions and all went well. One thing to add: after re-assembly of the (loaded) battery my razor would not turn on. At first I thought of a bad contact, but it turned out that the razor needed a few minutes plugged into the power supply. After that it worked fine. I suspect, that the load-control hardware needs the external power to reset itself.
Cheers, Nils
Nils Kay - Yanıt
Hello Nils!
Thanks for the hint.
Glad to hear that your razor works again!
Greetings
Daniel - Yanıt
Daniel, thank you very much for instruction.
Unfortunetly, into shaver I found only 1 battery.
Because used 3.7 v element, I prepared 2 x 1.2 v batteries.
Виктор Богачёв - Yanıt
My razor was the Panasonic ES8103S and the disassembly process was similar. From the pictures above, the battery looks the same. My razor actually had a piece under the slide-off cover that was totally rusted so I will just buy a new one on Amazon for $50. For future reference, I would like to know where you get the replacement battery? There is no model number on the battery and I couldn’t find any info online.
David Paul - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 72
Her zaman: 6,043
