Ana içeriğe geç
Panasonic ES2207P Motor Replacement
Neye ihtiyacın var
  1. Panasonic ES2207P Motor Replacement, Battery: adım 1, 1 resimden 1.
    • Remove foil head and blades.
  2. Panasonic ES2207P Motor Replacement: adım 2, 1 resimden 1.
    • Remove (2) 7.9mm Phillips #0 screws.
    • Remove (2) 14.3mm Phillips #0 screws.
  3. Panasonic ES2207P Motor Replacement: adım 3, 1 resimden 1.
    • Push the blade mount assembly towards the rear of razor and remove.
  4. Panasonic ES2207P Motor Replacement: adım 4, 1 resimden 1.
    • Be careful not to break any tabs that hold the panels to the body.
    • Remove both external panels using spudger if necessary.
  5. Panasonic ES2207P Motor Replacement: adım 5, 1 resimden 1.
  6. Panasonic ES2207P Motor Replacement: adım 6, 1 resimden 1.
    • This step may require a fair amount of force due to the O-ring.
    • Pull to separate the end-cap from the body.
  7. Panasonic ES2207P Motor Replacement: adım 7, 1 resimden 1.
    • Remove (2) 7.9mm Phillips #0 screws and remove endcap from frame.
  8. Panasonic ES2207P Motor Replacement: adım 8, 2 resimden 1. Panasonic ES2207P Motor Replacement: adım 8, 2 resimden 2.
    • Push forward on the lower terminal to remove the battery from the frame.
  9. Panasonic ES2207P Motor Replacement, Motor: adım 9, 2 resimden 1. Panasonic ES2207P Motor Replacement, Motor: adım 9, 2 resimden 2.
    • Remove battery contact.
  10. Panasonic ES2207P Motor Replacement: adım 10, 1 resimden 1.
    • Using pointed end of spudger, push on the motor through the hole in the back
  11. Panasonic ES2207P Motor Replacement: adım 11, 1 resimden 1.
    • Use your fingers to finish removing motor from frame.
Sonuç
Kevin Marvell
309 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S6-G5, Baechle Fall 2017 IUPUI, Team S6-G5, Baechle Fall 2017 üyesi
IUPUI-BAECHLE-F17S6G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 360
