Ana içeriğe geç
Panasonic HC‑VX870 Hand Strap Replacement
Neye ihtiyacın var
  1. Panasonic HC‑VX870 Hand Strap Replacement, Side Cover: adım 1, 3 resimden 1. Panasonic HC‑VX870 Hand Strap Replacement, Side Cover: adım 1, 3 resimden 2. Panasonic HC‑VX870 Hand Strap Replacement, Side Cover: adım 1, 3 resimden 3.
    • Unscrew the J1 screws on the left side of the camcorder.
    • Unscrew the marked screws on the bottom of the camcorder.
    • Unscrew the marked screws on the back of the camcorder.
  2. Panasonic HC‑VX870 Hand Strap Replacement: adım 2, 2 resimden 1. Panasonic HC‑VX870 Hand Strap Replacement: adım 2, 2 resimden 2.
    • Pull off the left side of the camcorder. You may have to use a little force but don't worry about breaking anything in the camcorder.
  3. Panasonic HC‑VX870 Hand Strap Replacement, Record Button Mechanism: adım 3, 1 resimden 1.
    • Unscrew the indicated screw.
  4. Panasonic HC‑VX870 Hand Strap Replacement: adım 4, 1 resimden 1.
    • Lift up on the little tab indicated in the picture and push away from the camera in order to remove the record button.
  5. Panasonic HC‑VX870 Hand Strap Replacement: adım 5, 3 resimden 1. Panasonic HC‑VX870 Hand Strap Replacement: adım 5, 3 resimden 2. Panasonic HC‑VX870 Hand Strap Replacement: adım 5, 3 resimden 3.
    • Take out the piece that that was held in place by the screw and separate the smaller piece from the larger piece.
  6. Panasonic HC‑VX870 Hand Strap Replacement, Hand Strap: adım 6, 1 resimden 1.
    • Use the plastic opening tool to pry the little metal bar out of place in order to release one side of the hand strap.
  7. Panasonic HC‑VX870 Hand Strap Replacement: adım 7, 1 resimden 1.
    • Unscrew the indicated screws and remove the piece it was holding in place.
  8. Panasonic HC‑VX870 Hand Strap Replacement: adım 8, 1 resimden 1.
    • Repeat step 3 for this side of the strap.
  9. Panasonic HC‑VX870 Hand Strap Replacement: adım 9, 1 resimden 1.
    • Pull the handle straps out of their holes to remove the strap.
Sonuç
Rebecca Maloney
501 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-6, Banghart Winter 2017 Cal Poly, Team 13-6, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S13G6
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 686
