Ana içeriğe geç
Panasonic HDC-TM15 Record Button Replacement
Neye ihtiyacın var
  1. Panasonic HDC-TM15 Record Button Replacement, Record Button: adım 1, 1 resimden 1.
    • Using the Phillips #00 Screwdriver, unscrew the five .5 mm Phillips #00 screws on the hand-strap side of the camcorder.
  2. Panasonic HDC-TM15 Record Button Replacement: adım 2, 1 resimden 1.
    • Unscrew the six .5 mm Phillips #00 screws on the bottom of the camcorder.
  3. Panasonic HDC-TM15 Record Button Replacement: adım 3, 3 resimden 1. Panasonic HDC-TM15 Record Button Replacement: adım 3, 3 resimden 2. Panasonic HDC-TM15 Record Button Replacement: adım 3, 3 resimden 3.
    • Once all eleven screws have been removed, put your hand through the hand-strap and tug on the side cover until it comes off completely.
    • The inside of your camcorder should now be completely exposed, as shown in the photos.
  4. Panasonic HDC-TM15 Record Button Replacement: adım 4, 2 resimden 1. Panasonic HDC-TM15 Record Button Replacement: adım 4, 2 resimden 2.
    • Unscrew the two 1 mm Phillips #00 black screws in the corners of the green memory card reader.
    • The screws should be surrounded by orange circles.
  5. Panasonic HDC-TM15 Record Button Replacement: adım 5, 1 resimden 1.
    • Unscrew the black 1 mm Phillips #00 black screw in the left center beside the green motherboard.
  6. Panasonic HDC-TM15 Record Button Replacement: adım 6, 2 resimden 1. Panasonic HDC-TM15 Record Button Replacement: adım 6, 2 resimden 2.
    • Unscrew the 1.2 mm Phillips #00 black screw beneath the motherboard on the bottom of the camcorder.
    • The green motherboard should now be partially detached, as shown in the photo.
  7. Panasonic HDC-TM15 Record Button Replacement: adım 7, 3 resimden 1. Panasonic HDC-TM15 Record Button Replacement: adım 7, 3 resimden 2. Panasonic HDC-TM15 Record Button Replacement: adım 7, 3 resimden 3.
    • Remove the long silver plate that secures the record button.
  8. Panasonic HDC-TM15 Record Button Replacement: adım 8, 1 resimden 1.
    • Remove the old record button from beneath the silver plate.
  9. Panasonic HDC-TM15 Record Button Replacement: adım 9, 2 resimden 1. Panasonic HDC-TM15 Record Button Replacement: adım 9, 2 resimden 2.
    • Place the new Record button into the open slot.
  10. Panasonic HDC-TM15 Record Button Replacement: adım 10, 2 resimden 1. Panasonic HDC-TM15 Record Button Replacement: adım 10, 2 resimden 2.
    • Slide the silver plate into place beside the new Record button.
    • Ensure that the Battery Eject button is lined up properly.
  11. Panasonic HDC-TM15 Record Button Replacement: adım 11, 2 resimden 1. Panasonic HDC-TM15 Record Button Replacement: adım 11, 2 resimden 2.
    • Re-screw the green motherboard into place and re-attach the side cover to your camcorder.
    • When the side cover is securely fastened, you have completed the Record Button replacement of your Panasonic HDC-TM15 camcorder.
Sonuç
Emma
176 İtibar
1 Kılavuz yazıldı
Ekip
Marist, Team 1-4, Laflen Spring 2015 Marist, Team 1-4, Laflen Spring 2015 üyesi
MARS-LAFLEN-S15S1G4
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 394
