Ana içeriğe geç
Panasonic HDC-TM15 Side Cover Replacement
Neye ihtiyacın var
  1. Panasonic HDC-TM15 Side Cover Replacement, Side Cover: adım 1, 1 resimden 1.
    • Using the Phillips #00 Screwdriver, unscrew the five .5 mm Phillips #00 screws on the hand-strap side of the camcorder.
  2. Panasonic HDC-TM15 Side Cover Replacement: adım 2, 1 resimden 1.
    • Next, unscrew the six .5 mm Phillips #00 screws on the bottom of the camcorder.
  3. Panasonic HDC-TM15 Side Cover Replacement: adım 3, 3 resimden 1. Panasonic HDC-TM15 Side Cover Replacement: adım 3, 3 resimden 2. Panasonic HDC-TM15 Side Cover Replacement: adım 3, 3 resimden 3.
    • By putting your hand through the hand-strap, tug on the side cover until it comes off completely.
    • Once the old cover is completely detached, set it aside.
    • The inside of your camcorder should now be completely exposed, as seen in the photos.
  4. Panasonic HDC-TM15 Side Cover Replacement: adım 4, 2 resimden 1. Panasonic HDC-TM15 Side Cover Replacement: adım 4, 2 resimden 2.
    • Line up the new side cover in the exact same place, ensuring that the screw holes match.
    • Re-screw the side cover into place.
  5. Panasonic HDC-TM15 Side Cover Replacement: adım 5, 1 resimden 1.
    • Gently tug on the hand-strap to ensure that the screws are tight and the side cover is secure.
    • When the side cover is securely fastened, you have completed the side cover replacement of your Panasonic HDC-TM15 camcorder.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tricia Fallo
210 İtibar
2 adet Kılavuz yazıldı
Ekip
Marist, Team 1-4, Laflen Spring 2015 Marist, Team 1-4, Laflen Spring 2015 üyesi
MARS-LAFLEN-S15S1G4
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 361
