Ana içeriğe geç
Panasonic HDC-TM90 LCD Screen Replacement
Neye ihtiyacın var
    1. Panasonic HDC-TM90 LCD Screen Replacement, Battery: adım 1, 1 resimden 1.
      • Open the LCD screen.
      FixBot'a Sor
      Yorum Ekle
    2. Panasonic HDC-TM90 LCD Screen Replacement: adım 2, 1 resimden 1.
      • Slide the battery release switch away from the battery.
      FixBot'a Sor
      Yorum Ekle
    3. Panasonic HDC-TM90 LCD Screen Replacement: adım 3, 1 resimden 1.
      • While holding the switch away from the battery, push the battery out of the slot.
      FixBot'a Sor
      Yorum Ekle
    4. Panasonic HDC-TM90 LCD Screen Replacement: adım 4, 1 resimden 1.
      • Remove the battery from the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Panasonic HDC-TM90 LCD Screen Replacement, Lens: adım 5, 3 resimden 1. Panasonic HDC-TM90 LCD Screen Replacement, Lens: adım 5, 3 resimden 2. Panasonic HDC-TM90 LCD Screen Replacement, Lens: adım 5, 3 resimden 3.
      • Remove 5 screws from the side panel body of the camcorder.
      • Use the spudger to remove the top of the camcorder.
      FixBot'a Sor
      Yorum Ekle
    2. Panasonic HDC-TM90 LCD Screen Replacement: adım 6, 2 resimden 1. Panasonic HDC-TM90 LCD Screen Replacement: adım 6, 2 resimden 2.
      • Unscrew three screws to remove the lens rim on the front of the camcorder.
      • Be aware of the wires attaching the lens rim to the body of the camcorder. You will not be able to separate the lens rim completely.
      • Use caution when separating the shutter lever.
      FixBot'a Sor
      Yorum Ekle
    3. Panasonic HDC-TM90 LCD Screen Replacement: adım 7, 1 resimden 1.
      • Remove the rubber ring around the lens.
      FixBot'a Sor
      Yorum Ekle
    4. Panasonic HDC-TM90 LCD Screen Replacement: adım 8, 1 resimden 1.
      • Unscrew the lens by removing the three screws connected to it.
      FixBot'a Sor
      Yorum Ekle
    1. Panasonic HDC-TM90 LCD Screen Replacement, LCD Screen: adım 9, 2 resimden 1. Panasonic HDC-TM90 LCD Screen Replacement, LCD Screen: adım 9, 2 resimden 2.
      • Remove the side panel of the camcorder.
      • Remove the top panel of the camcorder.
      • For help with this step see prerequisite guide: Lens Clean.
      FixBot'a Sor
      Yorum Ekle
    2. Panasonic HDC-TM90 LCD Screen Replacement: adım 10, 1 resimden 1.
      • Open camcorder screen.
      FixBot'a Sor
      Yorum Ekle
    3. Panasonic HDC-TM90 LCD Screen Replacement: adım 11, 1 resimden 1.
      • Turn the LCD screen perpendicular to the camcorder.
      • Remove the screws.
      • Have caution when you remove the screen. There is a wire connecting it to the rest of the camera that should not be detached.
      FixBot'a Sor
      Yorum Ekle
    4. Panasonic HDC-TM90 LCD Screen Replacement: adım 12, 1 resimden 1.
      • Carefully pry the plastic backing on the screen using a metal spudger.
      FixBot'a Sor
      Yorum Ekle
    5. Panasonic HDC-TM90 LCD Screen Replacement: adım 13, 2 resimden 1. Panasonic HDC-TM90 LCD Screen Replacement: adım 13, 2 resimden 2.
      • Peel back the black tape holding the wire strip to the camcorder screen.
      • Unclip the small latch from the wire strip.
      FixBot'a Sor
      Yorum Ekle
    6. Panasonic HDC-TM90 LCD Screen Replacement: adım 14, 1 resimden 1.
      • Remove the screws from the metal frame.
      • Be careful when holding the screen after the frame has been unscrewed. The screen and all of its components are unattached and can fall apart.
      FixBot'a Sor
      Yorum Ekle
Sonuç
BayleeVersteeg
37 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 8-4, Whitney Spring 2017 Baylor, Team 8-4, Whitney Spring 2017 üyesi
BU-WHITNEY-S17S8G4
3 Üyeler
9 adet Kılavuz yazıldı
1Rehber Yorum
Steps 1-4 are good pre-reqs.
Are all of steps 5-8 absolutely necessary for LCD screen replacement?
Step 9-bullet 3: Change to 'note' rather than bullet point and put it first.
Step 11-bullet 2: List the # of screws to be removed and with what screwdriver. Show 2nd picture of screws to remove on actual LCD door.
Step 11-bullet 3: Change to a "caution" rather than just a bullet. Also we had a spring fall out at this step with no idea where it came from. Perhaps you could address this.
Step 12- We actually had to use a 2nd spudger to pry it apart. One as a wedge and one as a lever to separate.
Step 14-bullet 2: change to a "Warning" symbol.
Seems to be an incomplete guide, as the LCD screen is still affixed to the device.
Rene Klopf - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 878
