Ana içeriğe geç
Panasonic KX-E603 Printwheel Replacement
  1. Panasonic KX-E603 Printwheel Replacement, Ink Cartridge: adım 1, 2 resimden 1. Panasonic KX-E603 Printwheel Replacement, Ink Cartridge: adım 1, 2 resimden 2.
    • Open the lid of the typewriter.
  2. Panasonic KX-E603 Printwheel Replacement: adım 2, 2 resimden 1. Panasonic KX-E603 Printwheel Replacement: adım 2, 2 resimden 2.
    • To release the green locking lever, pull it towards you.
  3. Panasonic KX-E603 Printwheel Replacement: adım 3, 2 resimden 1. Panasonic KX-E603 Printwheel Replacement: adım 3, 2 resimden 2.
    • Gently lift to remove the old ink cartridge.
  4. Panasonic KX-E603 Printwheel Replacement, Printwheel: adım 4, 2 resimden 1. Panasonic KX-E603 Printwheel Replacement, Printwheel: adım 4, 2 resimden 2.
    • Firmly grasp either one, or both of the plastic printwheel ends protruding from the carriage as seen.
    • Gently lift the printwheel while slightly pushing forward to remove the printwheel from its housing.
Sonuç
To reassemble your device, follow these steps in reverse using your new printwheel.
Lindsay Stratis
491 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-1, Forte Spring 2015 Cal Poly, Team 17-1, Forte Spring 2015 üyesi
CPSU-FORTE-S15S17G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 415
