Ana içeriğe geç
Panasonic KX-T4000R Cordless Phone Antenna Replacement
Neye ihtiyacın var
  1. Panasonic KX-T4000R Cordless Phone Antenna Replacement, Removing the Back Panel: adım 1, 2 resimden 1. Panasonic KX-T4000R Cordless Phone Antenna Replacement, Removing the Back Panel: adım 1, 2 resimden 2.
    • Orient the phone so that the phone model and other descriptive information is facing upward.
    • Locate the two silver screws near the hinge where the battery is housed.
    • Remove the silver screws using a Phillips head #2 screwdriver.
  2. Panasonic KX-T4000R Cordless Phone Antenna Replacement: adım 2, 3 resimden 1. Panasonic KX-T4000R Cordless Phone Antenna Replacement: adım 2, 3 resimden 2. Panasonic KX-T4000R Cordless Phone Antenna Replacement: adım 2, 3 resimden 3.
    • Pull off the back panel of the phone.
    • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
  3. Panasonic KX-T4000R Cordless Phone Antenna Replacement, Antenna: adım 3, 2 resimden 1. Panasonic KX-T4000R Cordless Phone Antenna Replacement, Antenna: adım 3, 2 resimden 2.
    • Find the silver screw located in the red circle.
    • Using a Philips head #2 screwdriver, remove the screw holding the antenna in place.
  4. Panasonic KX-T4000R Cordless Phone Antenna Replacement: adım 4, 2 resimden 1. Panasonic KX-T4000R Cordless Phone Antenna Replacement: adım 4, 2 resimden 2.
    • Press the release button.
    • The release button is located in the red circle in the image to the left.
Sonuç
Elizabeth Kelly
501 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 15-1, Benson Fall 2012 Clemson, Team 15-1, Benson Fall 2012 üyesi
CLEM-BENSON-F12S15G1
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 1,864
