Ana içeriğe geç
Panasonic KX-TG6021M Back Speaker Replacement
Neye ihtiyacın var
  1. Panasonic KX-TG6021M Back Speaker Replacement, Battery: adım 1, 2 resimden 1. Panasonic KX-TG6021M Back Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the back cover down towards the bottom of the phone to remove.
  2. Panasonic KX-TG6021M Back Speaker Replacement: adım 2, 3 resimden 1. Panasonic KX-TG6021M Back Speaker Replacement: adım 2, 3 resimden 2. Panasonic KX-TG6021M Back Speaker Replacement: adım 2, 3 resimden 3.
    • Pull the top of the battery towards you to remove it from the phone.
  3. Panasonic KX-TG6021M Back Speaker Replacement, Front Panel: adım 3, 2 resimden 1. Panasonic KX-TG6021M Back Speaker Replacement, Front Panel: adım 3, 2 resimden 2.
    • Unscrew the two screws located at the bottom of the phone.
    • Use a PH00 Phillips head to remove the 9 mm screws.
  4. Panasonic KX-TG6021M Back Speaker Replacement: adım 4, 3 resimden 1. Panasonic KX-TG6021M Back Speaker Replacement: adım 4, 3 resimden 2. Panasonic KX-TG6021M Back Speaker Replacement: adım 4, 3 resimden 3.
    • Separate the back cover from the front cover by using a wedge.
    • Remove the back cover from the front cover by pulling them apart.
  5. Panasonic KX-TG6021M Back Speaker Replacement: adım 5, 1 resimden 1.
    • Remove three screws on the motherboard.
    • Pull the phone face off of the motherboard.
  6. Panasonic KX-TG6021M Back Speaker Replacement, Back Speaker: adım 6, 1 resimden 1.
    • Twist the back speaker and pull straight out to remove it from the case.
    • To completely remove the speaker from the motherboard, you will need to desolder the speaker cables.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Leah Meador
301 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-1, Baechle Fall 2016 IUPUI, Team 3-1, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S3G1
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 616
