Ana içeriğe geç
Panasonic KX-TG6641 Base Display Screen Replacement
Neye ihtiyacın var
  1. Panasonic KX-TG6641 Base Display Screen Replacement, Base Display Screen: adım 1, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove five screws from the back cover.
  2. Panasonic KX-TG6641 Base Display Screen Replacement: adım 2, 1 resimden 1.
    • To remove the back cover, use an iFixit opening tool and wedge the tool in between the loosened back charging case and the front plate.
    • Wiggle to loosen, be careful to not pry too hard as it could cause damage.
  3. Panasonic KX-TG6641 Base Display Screen Replacement: adım 3, 2 resimden 1. Panasonic KX-TG6641 Base Display Screen Replacement: adım 3, 2 resimden 2.
    • To access the display screen, use a Phillips #0 screwdriver to remove the screw on the bottom right corner of the electrical panel.
    • Unclip the wires hooked into the base.
    • It's not necessary to desolder the wires.
  4. Panasonic KX-TG6641 Base Display Screen Replacement: adım 4, 1 resimden 1.
    • Disconnect the two phone cable connectors.
    • Use a Phillips #0 to remove the screw that is fixed in the plastic holder for the connectors.
  5. Panasonic KX-TG6641 Base Display Screen Replacement: adım 5, 2 resimden 1. Panasonic KX-TG6641 Base Display Screen Replacement: adım 5, 2 resimden 2.
    • Move the electrical panel to the side.
    • Use a Phillips #0 to remove the four screws from the brown board and lift it to access the display screen.
    • Be aware, there is a screw under the control panel, it is indicated with the central red circle.
  6. Panasonic KX-TG6641 Base Display Screen Replacement: adım 6, 1 resimden 1.
    • Remove the current display screen from the electric panel.
    • Follow this process in reverse to replace the new display screen in its place.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 364
