Ana içeriğe geç
Panasonic KX-TG6641 Handset Display Screen Replacement
Neye ihtiyacın var
  1. Panasonic KX-TG6641 Handset Display Screen Replacement, Battery: adım 1, 2 resimden 1. Panasonic KX-TG6641 Handset Display Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the battery cover by sliding the cover piece down
  2. Panasonic KX-TG6641 Handset Display Screen Replacement: adım 2, 2 resimden 1. Panasonic KX-TG6641 Handset Display Screen Replacement: adım 2, 2 resimden 2.
    • Remove the two AAA batteries.
  3. Panasonic KX-TG6641 Handset Display Screen Replacement, Earpiece: adım 3, 1 resimden 1.
    • In order to remove the back of the phone, unscrew the two screws at the bottom corners on the back of the phone.
  4. Panasonic KX-TG6641 Handset Display Screen Replacement: adım 4, 2 resimden 1. Panasonic KX-TG6641 Handset Display Screen Replacement: adım 4, 2 resimden 2.
    • In order to remove the back of the phone, pry the back open by inserting the iFixit Opening tool in the space between the front and back of the phone.
  5. Panasonic KX-TG6641 Handset Display Screen Replacement: adım 5, 2 resimden 1. Panasonic KX-TG6641 Handset Display Screen Replacement: adım 5, 2 resimden 2.
    • Remove the earpiece cover by twisting the plastic earpiece clockwise to unlock.
  6. Panasonic KX-TG6641 Handset Display Screen Replacement: adım 6, 1 resimden 1.
    • Replace earpiece by heating wires with soldering iron.
    • Solder wires back to earpiece after installing the replacement earpiece.
  7. Panasonic KX-TG6641 Handset Display Screen Replacement, Handset Display Screen: adım 7, 2 resimden 1. Panasonic KX-TG6641 Handset Display Screen Replacement, Handset Display Screen: adım 7, 2 resimden 2.
    • Unscrew two screws at the bottom of the motherboard in order to remove.
  8. Panasonic KX-TG6641 Handset Display Screen Replacement: adım 8, 1 resimden 1.
    • Unhinge display screen from the motherboard and replace with the new screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
2 Yorum
Thanks it makes it very easy
Chas Lewis - Yanıt
Where to buy the screen in India?
Gunasekaran Alias Saranyan V - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 50
Her zaman: 2,519
