Ana içeriğe geç
Panasonic KX-TGA410C Keypad Replacement
Neye ihtiyacın var
  1. Panasonic KX-TGA410C Keypad Replacement, Keypad: adım 1, 3 resimden 1. Panasonic KX-TGA410C Keypad Replacement, Keypad: adım 1, 3 resimden 2. Panasonic KX-TGA410C Keypad Replacement, Keypad: adım 1, 3 resimden 3.
    • Slide the battery cover in a downwards motion to uncover the batteries.
    • Use the indentation on the case.
  2. Panasonic KX-TGA410C Keypad Replacement: adım 2, 1 resimden 1.
    • Remove the batteries by pulling them forward.
  3. Panasonic KX-TGA410C Keypad Replacement: adım 3, 3 resimden 1. Panasonic KX-TGA410C Keypad Replacement: adım 3, 3 resimden 2. Panasonic KX-TGA410C Keypad Replacement: adım 3, 3 resimden 3.
    • Use a Phillips #00 screwdriver and remove two 6.4 mm screws.
    • The screws are at the bottom right and left-hand corner.
  4. Panasonic KX-TGA410C Keypad Replacement: adım 4, 2 resimden 1. Panasonic KX-TGA410C Keypad Replacement: adım 4, 2 resimden 2.
    • Take an opening tool or pick and slide it in between the back and front cover all the way around the phone, then pull the back case off.
  5. Panasonic KX-TGA410C Keypad Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove one 6.4 mm screw from the top left corner of the phone.
  6. Panasonic KX-TGA410C Keypad Replacement: adım 6, 1 resimden 1.
    • Gently pull the circuit board back.
  7. Panasonic KX-TGA410C Keypad Replacement: adım 7, 1 resimden 1.
    • Pull the button pad out.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 621
