Ana içeriğe geç
Panasonic KX-TGA600M Keypad Replacement
Neye ihtiyacın var
  1. Panasonic KX-TGA600M Keypad Replacement, Battery: adım 1, 2 resimden 1. Panasonic KX-TGA600M Keypad Replacement, Battery: adım 1, 2 resimden 2.
    • On the back of the phone, remove battery cover.
    • Push down on the marked indentation and pull downwards.
  2. Panasonic KX-TGA600M Keypad Replacement: adım 2, 1 resimden 1.
    • Pull out to remove the battery.
  3. Panasonic KX-TGA600M Keypad Replacement, Keypad: adım 3, 1 resimden 1.
    • Once battery is removed, use the Phillips #00 screwdriver to remove the two silver screws at the bottom left and right corners on the back of the phone.
  4. Panasonic KX-TGA600M Keypad Replacement: adım 4, 3 resimden 1. Panasonic KX-TGA600M Keypad Replacement: adım 4, 3 resimden 2. Panasonic KX-TGA600M Keypad Replacement: adım 4, 3 resimden 3.
    • Pull the phone apart. The plastic opening tool may be needed.
    • The clear light piece will fall out, so make sure you place it next to the screws.
  5. Panasonic KX-TGA600M Keypad Replacement: adım 5, 3 resimden 1. Panasonic KX-TGA600M Keypad Replacement: adım 5, 3 resimden 2. Panasonic KX-TGA600M Keypad Replacement: adım 5, 3 resimden 3.
    • Use the Phillips #00 screwdriver to remove the three screws holding the circuit-board in place.
    • The screws are located in the top right corner, bottom left corner, and bottom right corner.
  6. Panasonic KX-TGA600M Keypad Replacement: adım 6, 1 resimden 1.
    • Once the screws are out, remove the charging contacts beneath the two bottom corner screws.
  7. Panasonic KX-TGA600M Keypad Replacement: adım 7, 1 resimden 1.
    • Remove the circuit board.
  8. Panasonic KX-TGA600M Keypad Replacement: adım 8, 1 resimden 1.
    • Pull back the black silicone keypad.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Incomplete explanation with what materials to clean
asalmoom - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 7
Son 30 gün: 17
Her zaman: 664
