Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Flip the handset over to expose the back panel, and slide the panel out to remove.
Carefully remove the two batteries by lifting up from one end.
Remove the two screws behind the battery panel by using a Philips size #00 screwdriver.
Using a spudger, open the device by starting from the bottom and working your way to the top.
Once the back has been separated from the rest of the device, carefully place it to the side. Be careful not to completely remove it, however, as there are wires connecting the back to the handset.
Using the same screwdriver as before, remove the Philips size #00 screw holding the motherboard in place.
With the screw removed, the front panel assembly can be separated from the rest of the device.
Detach the piece from the back panel. It should already be separate at this point, but it is important to ensure that it is since we'll be working exclusively with the back in this guide.
The back speaker is held in with a metal frame. To remove it, push the handles of the frame together with tweezers and lift. The speaker can now be easily taken out.
Use a soldering iron to loosen the soldering on the contact points so that you can easily remove the bad speaker.
You can now remove the speaker from its contact points. This should require minimal effort if you have completed the soldering step properly.
