Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This is the replacement guide for the power port for the primary charging base of the device. If you've followed the troubleshooting guide for this device and have determined that this is your issue, look no further than this guide. Please make sure that the issue is with the power port before you begin, however, as this is not an easy replacement, and fixing the issue will require soldering.
Neye ihtiyacın var
To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
Now that the device has been opened, the power port can easily be removed from its resting point.
