Ana içeriğe geç
Giriş
The TEL port is where the TEL cable plugs into on the device. If you've followed the symptoms listed in our troubleshooting guide and have determined that the TEL port is the issue, you'll need to follow this guide to reach it and replace it. Prior to beginning this guide, make sure you have access to a Philips Size #0 screwdriver and a soldering iron. Both will be needed to open the device and replace the component.
Parçalar
Hiçbir parça belirtilmedi.
  1. Panasonic KX-TGE233 TEL Port Replacement, Base Front Panel Assembly: adım 1, 1 resimden 1.
    • To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
  2. Panasonic KX-TGE233 TEL Port Replacement: adım 2, 1 resimden 1.
    • To start, we'll need to work with objects on the bottom of the device, so begin by flipping the device over.
  3. Panasonic KX-TGE233 TEL Port Replacement: adım 3, 1 resimden 1.
    • To open the main docking station, you'll need to remove four 11 mm Philips #0 screws.
  4. Panasonic KX-TGE233 TEL Port Replacement: adım 4, 1 resimden 1.
    • With the screws removed, you can use a spudger to aid in removing the back from the device.
    • Levering the back by the spudger may break the tool!
  5. Panasonic KX-TGE233 TEL Port Replacement: adım 5, 1 resimden 1.
    • With the back removed, we now have direct access to all other components in the main docking station.
  6. Panasonic KX-TGE233 TEL Port Replacement, TEL Port: adım 6, 1 resimden 1.
    • For easier access to its wires, you can easily remove the TEL port from its resting point in the device.
  7. Panasonic KX-TGE233 TEL Port Replacement: adım 7, 1 resimden 1.
  8. Panasonic KX-TGE233 TEL Port Replacement: adım 8, 1 resimden 1.
    • From here, you can remove the faulty port from the device. If the soldering step has been completed successfully, this should require minimal effort.
Sonuç
Jesse Satterwhite
643 İtibar
5 adet Kılavuz yazıldı
IUPUI, Team 2-2, Baechle Spring 2016 IUPUI, Team 2-2, Baechle Spring 2016 üyesi
IUPUI-BAECHLE-S16S2G2
5 Üyeler
14 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 341
