Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
To start, we'll need to work with objects on the bottom of the device, so begin by flipping the device over.
To open the main docking station, you'll need to remove four 11 mm Philips #0 screws.
With the screws removed, you can use a spudger to aid in removing the back from the device.
With the back removed, we now have direct access to all other components in the main docking station.
For easier access to its wires, you can easily remove the TEL port from its resting point in the device.
Use a soldering iron to loosen the solder on the contact points.
From here, you can remove the faulty port from the device. If the soldering step has been completed successfully, this should require minimal effort.
