Ana içeriğe geç
Giriş
Are you pressing the power button but your camera stays turned off? Replacing the battery is a quick fix that should solve this problem.
  1. Looking at the bottom of the camera, slide the OPEN/LOCK switch to the left into the OPEN position. The battery housing door should swing open. The battery housing door should swing open.
    • Looking at the bottom of the camera, slide the OPEN/LOCK switch to the left into the OPEN position.
    • The battery housing door should swing open.
  2. Flip the inside switch up to release the battery. Flip the inside switch up to release the battery.
    • Flip the inside switch up to release the battery.
  3. Grip the edge of the battery and pull it out.
    • Grip the edge of the battery and pull it out.
    • Use a LUMIX Panasonic DMW-BLE9PP Battery Pack for replacement.
Sonuç
Olivia Hillman
239 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 70-4, Forte Winter 2016 Cal Poly, Team 70-4, Forte Winter 2016 üyesi
CPSU-FORTE-W16S70G4
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 1,881
