Ana içeriğe geç
Panasonic Lumix DMC-F7 Battery Replacement
  1. Panasonic Lumix DMC-F7 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the lock switch to the right so that it is in the unlocked position.
    • Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
    • Both battery and memory card should now be visible.
  2. Panasonic Lumix DMC-F7 Battery Replacement: adım 2, 1 resimden 1.
    • Open the battery hatch and then the black cover to expose the battery compartment.
    • The camera used to create these repair guides did not have a battery and memory card.
    • Remove the battery.
    • When installing the new battery, ensure it is in the same orientation as before.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Hormoz Tarevern
170 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 7-35, Regan Winter 2011 Cal Poly, Team 7-35, Regan Winter 2011 üyesi
CPSU-REGAN-W11S7G35
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 2,316
