Ana içeriğe geç
Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the lock switch to the right so that it is in the unlocked position.
    • Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
    • Both battery and memory card should now be visible.
  2. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: adım 2, 1 resimden 1.
    • Open the battery hatch and then the black cover to expose the battery compartment.
    • The camera used to create these repair guides did not have a battery and memory card.
    • Remove the battery.
    • When installing the new battery, ensure it is in the same orientation as before.
  3. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement, Back Case: adım 3, 1 resimden 1.
    • Using the Phillips #00 screwdriver, remove the two 2.8 mm screws located under the hatch.
  4. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: adım 4, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the three 2.8 mm screws on the bottom of the camera.
  5. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: adım 5, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the two 2.8 mm screws on the side of the camera.
  6. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: adım 6, 2 resimden 1. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: adım 6, 2 resimden 2.
    • Use a spudger to pry open the case at all sides.
  7. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: adım 7, 2 resimden 1. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: adım 7, 2 resimden 2.
    • Be careful not to damage the ribbon cable when opening. Ensure it is still attached.
    • Use your fingers to carefully remove the back casing from the front of the camera.
  8. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: adım 8, 1 resimden 1.
    • Place the camera on a flat surface with the front side facing down.
    • Use the spudger to flip up the retaining flap and slide the ribbon cable out of the connector.
    • Hold down on the camera's metal casing with one hand. Using your other hand, remove the back case from the rest of the camera.
  9. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement, Replacing LCD Screen: adım 9, 2 resimden 1. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement, Replacing LCD Screen: adım 9, 2 resimden 2.
    • Use a spudger to lift the screen ZIF connector tab.
    • Use the back of the spudger to push the ribbon cable free.
  10. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: adım 10, 3 resimden 1. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: adım 10, 3 resimden 2. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: adım 10, 3 resimden 3.
    • Use the screwdriver to remove the four 2.4 mm Phillips screws.
    • Lift up the LCD screen from the front case.
    • Potential for device damage: The wire is still connected to the board in the other side.
  11. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: adım 11, 1 resimden 1.
    • Remove the LCD screen from its case.
  12. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: adım 12, 1 resimden 1.
    • Locate the wire connecting the LCD screen to the motherboard.
    • Use the soldering iron to desolder the wire.
    • Use the soldering iron to solder wires from new LCD screen to the circuit board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex Penman
463 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-35, Regan Winter 2011 Cal Poly, Team 7-35, Regan Winter 2011 üyesi
CPSU-REGAN-W11S7G35
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 3,002
