Ana içeriğe geç
Panasonic Lumix DMC-FH20 Battery Replacement
  1. Panasonic Lumix DMC-FH20 Battery Replacement, Battery: adım 1, 3 resimden 1. Panasonic Lumix DMC-FH20 Battery Replacement, Battery: adım 1, 3 resimden 2. Panasonic Lumix DMC-FH20 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • On the bottom of the camera, move the gray switch that has the words "open" and "lock" above it to the open position. The case will open.
  2. Panasonic Lumix DMC-FH20 Battery Replacement: adım 2, 3 resimden 1. Panasonic Lumix DMC-FH20 Battery Replacement: adım 2, 3 resimden 2. Panasonic Lumix DMC-FH20 Battery Replacement: adım 2, 3 resimden 3.
    • Once the case is open, there will be another switch on the right side of the battery. Push the switch to the right to release the battery. Now you can pull the battery out.
Sonuç
Arianna Boushell
626 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-7, Banghart Winter 2017 Cal Poly, Team 10-7, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S10G7
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 583
