Ana içeriğe geç
Panasonic Lumix DMC-FH20 Circuit Board Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-FH20 Circuit Board Replacement, Circuit Board: adım 1, 3 resimden 1. Panasonic Lumix DMC-FH20 Circuit Board Replacement, Circuit Board: adım 1, 3 resimden 2. Panasonic Lumix DMC-FH20 Circuit Board Replacement, Circuit Board: adım 1, 3 resimden 3.
    • Remove all screws (Phillips #000 head) from the sides and bottom of the camera.
  2. Panasonic Lumix DMC-FH20 Circuit Board Replacement: adım 2, 1 resimden 1.
    • Remove the back panel. This might require some extra force. If you still can't get the panel off, try to use a plastic opening tool.
  3. Panasonic Lumix DMC-FH20 Circuit Board Replacement: adım 3, 2 resimden 1. Panasonic Lumix DMC-FH20 Circuit Board Replacement: adım 3, 2 resimden 2.
    • Remove the circuit board. You should be able to do this with your fingers. Just grab it and pull upwards. If it does not come, use a plastic opening tool to help.
Sonuç
Arianna Boushell
626 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-7, Banghart Winter 2017 Cal Poly, Team 10-7, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S10G7
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 324
