Ana içeriğe geç
Panasonic Lumix DMC-FH20 LCD Screen Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 1. Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 2. Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 3.
    • Remove all screws (Phillips #000 head) from the sides and bottom of the camera.
  2. Panasonic Lumix DMC-FH20 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Remove the back panel. This might require some extra force. If you still can't get the panel off, try to use a plastic opening tool.
  3. Panasonic Lumix DMC-FH20 LCD Screen Replacement: adım 3, 2 resimden 1. Panasonic Lumix DMC-FH20 LCD Screen Replacement: adım 3, 2 resimden 2.
    • Remove the circuit board. You should be able to do this with your fingers. Just grab it and pull upwards. If it does not come, use a plastic opening tool to help.
  4. Panasonic Lumix DMC-FH20 LCD Screen Replacement: adım 4, 2 resimden 1. Panasonic Lumix DMC-FH20 LCD Screen Replacement: adım 4, 2 resimden 2.
    • Remove the white plastic cover. This may take some extra force. You will want to try to remove from the bottom side first and peel up.
    • Then, where the silver switch is located, it will slide directly out at the top.
  5. Panasonic Lumix DMC-FH20 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Unscrew one screw (Phillips #000 head).
  6. Panasonic Lumix DMC-FH20 LCD Screen Replacement: adım 6, 3 resimden 1. Panasonic Lumix DMC-FH20 LCD Screen Replacement: adım 6, 3 resimden 2. Panasonic Lumix DMC-FH20 LCD Screen Replacement: adım 6, 3 resimden 3.
    • You will want to use a plastic opening tool to complete this step. Pop the thin black piece of plastic upwards with the opening tool to unlock the plastic film ribbon.
    • Once unlocked, you will be able to pull the ribbon out and remove the screen completely.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Arianna Boushell
626 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-7, Banghart Winter 2017 Cal Poly, Team 10-7, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S10G7
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 539
