Ana içeriğe geç
Panasonic Lumix DMC-FH20 Lens Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-FH20 Lens Replacement, Lens: adım 1, 3 resimden 1. Panasonic Lumix DMC-FH20 Lens Replacement, Lens: adım 1, 3 resimden 2. Panasonic Lumix DMC-FH20 Lens Replacement, Lens: adım 1, 3 resimden 3.
    • Remove all screws (Phillips #000 head) from the sides and bottom of the camera.
  2. Panasonic Lumix DMC-FH20 Lens Replacement: adım 2, 2 resimden 1. Panasonic Lumix DMC-FH20 Lens Replacement: adım 2, 2 resimden 2.
    • Remove the back panel. This might require some extra force. If you still can't get the panel off, try to use a plastic opening tool.
  3. Panasonic Lumix DMC-FH20 Lens Replacement: adım 3, 2 resimden 1. Panasonic Lumix DMC-FH20 Lens Replacement: adım 3, 2 resimden 2.
    • Remove the circuit board. You should be able to do this with your fingers. Just grab it and pull upwards. If it does not come, use a plastic opening tool to help.
  4. Panasonic Lumix DMC-FH20 Lens Replacement: adım 4, 2 resimden 1. Panasonic Lumix DMC-FH20 Lens Replacement: adım 4, 2 resimden 2.
    • Remove the white plastic cover. This may take some extra force. You will want to try to remove from the bottom side first and peel up.
    • Then, where the silver switch is located, it will slide directly out at the top.
  5. Panasonic Lumix DMC-FH20 Lens Replacement: adım 5, 3 resimden 1. Panasonic Lumix DMC-FH20 Lens Replacement: adım 5, 3 resimden 2. Panasonic Lumix DMC-FH20 Lens Replacement: adım 5, 3 resimden 3.
    • Unscrew one screw (Phillips #000 head)
    • Remove the screen. You will want to use a plastic opening tool to complete this step. Pop the thin black piece of plastic upwards with the opening tool to unlock the plastic film ribbon.
    • Once unlocked, you will be able to pull the ribbon out and remove the screen completely.
  6. Panasonic Lumix DMC-FH20 Lens Replacement: adım 6, 3 resimden 1. Panasonic Lumix DMC-FH20 Lens Replacement: adım 6, 3 resimden 2. Panasonic Lumix DMC-FH20 Lens Replacement: adım 6, 3 resimden 3.
    • Remove the grey panel.
    • You will need to unscrew three screws (Phillips #000 head) in order to remove the panel.
  7. Panasonic Lumix DMC-FH20 Lens Replacement: adım 7, 3 resimden 1. Panasonic Lumix DMC-FH20 Lens Replacement: adım 7, 3 resimden 2. Panasonic Lumix DMC-FH20 Lens Replacement: adım 7, 3 resimden 3.
    • Pop the two thin black pieces of plastic upwards with the opening tool to unlock the plastic film ribbons.
    • Once unlocked, you will need to unscrew six more screws (Phillips #000 head) to completely detach the lens from the rest of the camera.
  8. Panasonic Lumix DMC-FH20 Lens Replacement: adım 8, 2 resimden 1. Panasonic Lumix DMC-FH20 Lens Replacement: adım 8, 2 resimden 2.
    • Remove the lens from the camera carefully. You can do this simply by grabbing it with your fingers and pulling out gently.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Arianna Boushell
626 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-7, Banghart Winter 2017 Cal Poly, Team 10-7, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S10G7
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 27
Her zaman: 916
