Ana içeriğe geç
Panasonic Lumix DMC-FH20 Memory Card Replacement
  1. Panasonic Lumix DMC-FH20 Memory Card Replacement, Memory Card: adım 1, 3 resimden 1. Panasonic Lumix DMC-FH20 Memory Card Replacement, Memory Card: adım 1, 3 resimden 2. Panasonic Lumix DMC-FH20 Memory Card Replacement, Memory Card: adım 1, 3 resimden 3.
    • On the bottom of the camera, move the gray switch that has the words "open" and "lock" above it to the open position. The case will open.
  2. Panasonic Lumix DMC-FH20 Memory Card Replacement: adım 2, 1 resimden 1.
    • Once the case is open, you will see your memory card in the marked slot. Push the card down until you hear a small click. The card will then pop out and you will be able to remove it.
Sonuç
Arianna Boushell
626 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-7, Banghart Winter 2017 Cal Poly, Team 10-7, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S10G7
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 268
