Ana içeriğe geç
Panasonic Lumix DMC-FH25 Front Case Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-FH25 Front Case Replacement, Front Case: adım 1, 3 resimden 1. Panasonic Lumix DMC-FH25 Front Case Replacement, Front Case: adım 1, 3 resimden 2. Panasonic Lumix DMC-FH25 Front Case Replacement, Front Case: adım 1, 3 resimden 3.
    • Remove four screws on the front case using a 00 Phillips head screwdriver. Two will be on the side with the camera strap, one on the bottom, and one on the side opposing the camera strap. They will be in pairs, one screw holding the front case and one screw holding the back case.
  2. Panasonic Lumix DMC-FH25 Front Case Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool and your hands, pull the front case loose from the camera.
  3. Panasonic Lumix DMC-FH25 Front Case Replacement: adım 3, 2 resimden 1. Panasonic Lumix DMC-FH25 Front Case Replacement: adım 3, 2 resimden 2.
    • Remove the front case from the camera.
Sonuç
Janice Weldon
612 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G6, Isaacson Spring 2017 UMass Dartmouth, Team S6-G6, Isaacson Spring 2017 üyesi
UMASSD-ISAACSON-S17S6G6
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 274
