Giriş
Removing and replacing the front case is an incredibly easy task. It is useful if the case is damaged or broken, or if the user wants to change colors. Additionally, removing the front case is necessary if the user needs to replace any of the parts beneath, such as the lens assembly.
Neye ihtiyacın var
Remove four screws on the front case using a 00 Phillips head screwdriver. Two will be on the side with the camera strap, one on the bottom, and one on the side opposing the camera strap. They will be in pairs, one screw holding the front case and one screw holding the back case.
