Ana içeriğe geç
Panasonic Lumix DMC-FX01 Front Casing Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-FX01 Front Casing Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 Front Casing Replacement: adım 2, 1 resimden 1.
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 Front Casing Replacement: adım 3, 1 resimden 1.
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 Front Casing Replacement, Rear Casing: adım 4, 1 resimden 1.
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 Front Casing Replacement: adım 5, 1 resimden 1.
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 Front Casing Replacement: adım 6, 2 resimden 1. Panasonic Lumix DMC-FX01 Front Casing Replacement: adım 6, 2 resimden 2.
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 Front Casing Replacement: adım 7, 1 resimden 1.
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 Front Casing Replacement: adım 8, 1 resimden 1.
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 Front Casing Replacement: adım 9, 2 resimden 1. Panasonic Lumix DMC-FX01 Front Casing Replacement: adım 9, 2 resimden 2.
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 Front Casing Replacement, LCD Screen: adım 10, 1 resimden 1.
    • Gently lift up the LCD screen.
    • Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
    • It should fall out on its own or with a gentle tug.
  11. Panasonic Lumix DMC-FX01 Front Casing Replacement: adım 11, 1 resimden 1.
    • Gently tug the thicker ribbon to remove it from its housing.
  12. Panasonic Lumix DMC-FX01 Front Casing Replacement, Front Casing: adım 12, 2 resimden 1. Panasonic Lumix DMC-FX01 Front Casing Replacement, Front Casing: adım 12, 2 resimden 2.
    • Remove the two black 5.4 mm screws that hold in the front faceplate using a Phillips #00 screwdriver.
    • There may be a third screw the the right of the lens assembly.
  13. Panasonic Lumix DMC-FX01 Front Casing Replacement: adım 13, 3 resimden 1. Panasonic Lumix DMC-FX01 Front Casing Replacement: adım 13, 3 resimden 2. Panasonic Lumix DMC-FX01 Front Casing Replacement: adım 13, 3 resimden 3.
    • Carefully remove the upper assembly, which houses the buttons and the flash battery.
  14. Panasonic Lumix DMC-FX01 Front Casing Replacement: adım 14, 1 resimden 1.
    • Carefully remove the front casing after verifying that the thin plastic around the lens is not still attached.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Andrew
396 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-22, Regan Fall 2010 Cal Poly, Team 9-22, Regan Fall 2010 üyesi
CPSU-REGAN-F10S9G22
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 4,299
