1. Locate the memory card and battery card latch on the bottom of the camera.
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Open the battery latch, and slide the battery release lever to the right.
    • Open the battery latch, and slide the battery release lever to the right.
  3. Remove the battery from the camera.
    • Remove the battery from the camera.
  4. Using a size #00 Phillips screwdriver, remove the three 4.58 mm screws on the bottom of the camera.
    • Using a size #00 Phillips screwdriver, remove the three 4.58 mm screws on the bottom of the camera.
    • Use this screwdriver for all screws in the device.
  5. Remove the 3.15 mm screw on the left side of the camera.
    • Remove the 3.15 mm screw on the left side of the camera.
  6. Remove the left side casing. Remove the left side casing.
    • Remove the left side casing.
  7. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  8. Remove the two 3.15 mm screws on the right side of the camera.
    • Remove the two 3.15 mm screws on the right side of the camera.
  9. Remove the bottom right panel.
    • Remove the bottom right panel.
  10. Gently remove the back casing. Start at the bottom and carefully pry towards the top to get this piece free.
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  11. Gently lift up the LCD screen.
    • Gently lift up the LCD screen.
    • Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
    • It should fall out on its own or with a gentle tug.
  12. Gently tug the thicker ribbon to remove it from its housing.
    • Gently tug the thicker ribbon to remove it from its housing.
  13. Carefully remove the upper assembly, which houses the buttons and the flash battery. Carefully remove the upper assembly, which houses the buttons and the flash battery.
    • Carefully remove the upper assembly, which houses the buttons and the flash battery.
  14. Remove the two 3mm screws.
    • Remove the two 3mm screws.
  15. Pry bars back gently as shown. Fingers can be used but tool is shown for clarity.
    • Pry bars back gently as shown.
    • Fingers can be used but tool is shown for clarity.
  16. After, releasing all the components, gently remove the flash assembly from the casing. After, releasing all the components, gently remove the flash assembly from the casing.
    • After, releasing all the components, gently remove the flash assembly from the casing.
  17. Remove the 1.2 mm screw from the settings wheel.
    • Remove the 1.2 mm screw from the settings wheel.
  18. Replace buttons.
    • Replace buttons.
    • Replace the "On/ Off" button with the prongs facing away from the flash.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Andrew
381 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 9-22, Regan Fall 2010 Cal Poly, Team 9-22, Regan Fall 2010 üyesi
CPSU-REGAN-F10S9G22
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Olá ! Sugiro ter cuidado com a carga do capacitor do flash, melhor descarrega-lo com auxílio de uma lâmpada ou resistor
para evitar um choque elétrico.
Ricardo Britto - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 11
Her zaman: 4,634
