Ana içeriğe geç
Panasonic Lumix DMC-FX01 Rear Casing Replacement
Neye ihtiyacın var
    1. Panasonic Lumix DMC-FX01 Rear Casing Replacement, Battery: adım 1, 1 resimden 1.
      • Locate the memory card and battery card latch on the bottom of the camera.
      • Slide the latch to the open position.
      FixBot'a Sor
      Yorum Ekle
    2. Panasonic Lumix DMC-FX01 Rear Casing Replacement: adım 2, 1 resimden 1.
      • Open the battery latch, and slide the battery release lever to the right.
      FixBot'a Sor
      Yorum Ekle
    3. Panasonic Lumix DMC-FX01 Rear Casing Replacement: adım 3, 1 resimden 1.
      • Remove the battery from the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Panasonic Lumix DMC-FX01 Rear Casing Replacement, Rear Casing: adım 4, 1 resimden 1.
      • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Panasonic Lumix DMC-FX01 Rear Casing Replacement: adım 5, 1 resimden 1.
      • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Panasonic Lumix DMC-FX01 Rear Casing Replacement: adım 6, 2 resimden 1. Panasonic Lumix DMC-FX01 Rear Casing Replacement: adım 6, 2 resimden 2.
      • Remove the left side casing.
      FixBot'a Sor
      Yorum Ekle
    4. Panasonic Lumix DMC-FX01 Rear Casing Replacement: adım 7, 1 resimden 1.
      • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. Panasonic Lumix DMC-FX01 Rear Casing Replacement: adım 8, 1 resimden 1.
      • Remove the bottom right panel.
      FixBot'a Sor
      Yorum Ekle
    6. Panasonic Lumix DMC-FX01 Rear Casing Replacement: adım 9, 2 resimden 1. Panasonic Lumix DMC-FX01 Rear Casing Replacement: adım 9, 2 resimden 2.
      • Gently remove the back casing.
      • Start at the bottom and carefully pry towards the top to get this piece free.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew
396 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-22, Regan Fall 2010 Cal Poly, Team 9-22, Regan Fall 2010 üyesi
CPSU-REGAN-F10S9G22
4 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 31
Her zaman: 3,833
