Giriş
This guide will show you how to remove the motherboard so you can replace it.
Neye ihtiyacın var
Using the spudger, pry off the top cover by gliding the spudger along the entire edge between the top cover and the front cover.
Remove the small screw in the hole towards the top of the camera(#00P, 5.4mm).
Gently lift the tabs on the ZIF connectors connecting the lens to the front motherboard.
Neredeyse bitti!
Sonuç
