Giriş
This guide is fairly simple in regards to the general disassembly of the device. However, it does require caution when dealing with the delicate ribbon cables. Additionally, the LCD screen is secured in place by a small amount of adhesive. If you are having any difficulty prying free the screen, I would suggest applying a very low amount of heat to the front of the screen (display side) to melt the adhesive.
Neye ihtiyacın var
Remove both of the 3 mm screws on the bottom of the camera connected to the side panel.
