Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove both of the 3 mm screws on the bottom of the camera connected to the side panel.
Remove the remaining 3 mm screw holding on the side panel and remove the panel entirely.
On the opposite side of the camera, remove the two 3 mm screws.
Remove the bottom side panel and place it with its respective 3 mm screw.
Remove the front panel (the panel around the lens casing) from the camera.
Remove the two ribbon cables connected to the back panel (the panel this the LCD screen) by lifting up on their respective tabs and gently pulling out the cord.
Remove the back panel from the camera.
Remove the top control panel (connected to the flash battery) from the camera.
Locate and remove the silver 2mm screw on the protection panel.
Remove the three black 8mm screws that remain.
Proceed to remove the protection panel entirely.
Insert the flat end of a plastic spudger underneath the motherboard and twist. This will disconnect the board from the device and allow it to be removed.
Use the pointed end of the spudger to lift the black tabs holding the ribbon cable connected to the photoreceptor in place.
Remove the three 3mm screws holding the photoreceptor in place.
Carefully lift the photoreceptor, disconnecting the ribbon cable and remove the photoreceptor from the device.
Bir başkası bu kılavuzu tamamladı.
