Ana içeriğe geç
Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement, Loose Digitizer Cable: adım 1, 1 resimden 1.
    • Power off your device by locating the on/off switch on top of camera.
  2. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: adım 2, 3 resimden 1. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: adım 2, 3 resimden 2. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: adım 2, 3 resimden 3.
    • Remove the screw located on the right side of the camera.
    • Remove the screw located on the bottom right of the camera, and remove the cover from the camera.
  3. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: adım 3, 1 resimden 1.
    • Remove the screw located on the base of the camera.
  4. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: adım 4, 1 resimden 1.
    • Pry the top part of the camera slowly. Be careful not to tear the digitilizer cable.
  5. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: adım 5, 2 resimden 1. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: adım 5, 2 resimden 2.
    • Open the bigger clamp using a spudger or other tools. Repeat for the smaller clamp.
  6. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: adım 6, 2 resimden 1. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: adım 6, 2 resimden 2.
    • Carefully take the thin ribbon and insert cable end into the latch. Do this for both sides.
  7. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: adım 7, 3 resimden 1. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: adım 7, 3 resimden 2. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: adım 7, 3 resimden 3.
    • Once the ribbon is placed into the latch, carefully close the clamps by lowering the clamp into a down position. Repeat this step for both sides.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 350
