Ana içeriğe geç
Panasonic Lumix DMC-FX9 Selector Buttons Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-FX9 Selector Buttons Replacement, Selector Buttons: adım 1, 1 resimden 1.
    • Make sure the power is off by switching the power switch to the left.
  2. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: adım 2, 2 resimden 1. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the screws on the left side of the camera.
  3. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: adım 3, 1 resimden 1.
    • Remove the screws on the right side of the camera by using the Philips #00 screwdriver.
  4. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: adım 4, 2 resimden 1. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: adım 4, 2 resimden 2.
    • Remove the screws on the bottom side of the camera using the Philips #00 Screwdriver.
    • Separate the covers by gently applying force upwards, carefully placing the opening tool between the two covers.
  5. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: adım 5, 2 resimden 1. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: adım 5, 2 resimden 2.
    • Lift the ZIF tabs up with the opening tool and carefully remove the digitizer ribbon cables.
    • Remove the LCD Screen from the glass frame carefully with the opening tool.
  6. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: adım 6, 2 resimden 1. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: adım 6, 2 resimden 2.
    • Push on the back panel buttons on the front side to remove the buttons.
    • Be cautious of the adhesive holding the button panels to the cover. Apply extra force if necessary.
Sonuç
Kriselle Tubongbanua
133 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 292
