Ana içeriğe geç
Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: adım 1, 3 resimden 1. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: adım 1, 3 resimden 2. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: adım 1, 3 resimden 3.
    • Remove the four 4.6mm J000 Phillips screws from the sides and two 3.2mm J000 Phillips screws along the bottom.
  2. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: adım 2, 3 resimden 1. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: adım 2, 3 resimden 2. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: adım 2, 3 resimden 3.
    • Remove the two 3.2mm J000 Phillips screws located on the bottom edge of the viewfinder cover.
    • Carefully remove the viewfinder cover.
    • Remove the two 4.4mm J000 Phillips screws located near the top edge of the viewfinder.
  3. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: adım 3, 3 resimden 1. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: adım 3, 3 resimden 2. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: adım 3, 3 resimden 3.
    • Slide the Wide Plastic Opening Tool upwards along the underside of the rear casing.
    • Be careful not to disconnect the filament connections. Reinserting them can be difficult.
    • Slowly lower the casing into the position shown.
  4. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: adım 4, 2 resimden 1. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: adım 4, 2 resimden 2.
    • Use the Screwdriver J000 Phillips Head to remove the screw located at the lower-left corner of the face of the viewfinder glass.
    • Carefully lift the L-shaped clicker underneath the previously removed screw.
  5. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: adım 5, 2 resimden 1. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: adım 5, 2 resimden 2.
    • Slide the faulty diopter adjustment dial off the rod.
    • Replace the diopter dial with a 1-cm wheel.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Gabriel Gonzalez Jr
325 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Kass Spring 2017 USF Tampa, Team 1-3, Kass Spring 2017 üyesi
USFT-KASS-S17S1G3
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 1,112
