Ana içeriğe geç
Panasonic Lumix DMC-G5 LCD Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-G5 LCD Replacement, LCD: adım 1, 2 resimden 1. Panasonic Lumix DMC-G5 LCD Replacement, LCD: adım 1, 2 resimden 2.
    • Use J0 screwdriver to remove the two 3.2 mm screws from the outside of the assembly.
    • Use the J0 screwsdriver to remove the two 5.6 mm screws from the inside of the face near the swivel.
    • Rotate the face to more easily gain access to the screws.
  2. Panasonic Lumix DMC-G5 LCD Replacement: adım 2, 2 resimden 1. Panasonic Lumix DMC-G5 LCD Replacement: adım 2, 2 resimden 2.
    • Slide the wide plastic opening tool underneath the crack of the side of the face and separate the components.
  3. Panasonic Lumix DMC-G5 LCD Replacement: adım 3, 1 resimden 1.
    • Carefully remove the filament connections from the LCD backing by lifting the black lever up first on the connector, then pulling gently outward from the LCD backing with your fingers.
    • Replace the filament connections into the backing of the new LCD face to complete replacement..
Sonuç
Bir başkası bu kılavuzu tamamladı.
Gabriel Gonzalez Jr
325 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Kass Spring 2017 USF Tampa, Team 1-3, Kass Spring 2017 üyesi
USFT-KASS-S17S1G3
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 25
Her zaman: 2,129
