Ana içeriğe geç
Panasonic Lumix DMC-G5 Motherboard Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-G5 Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove four JIS #000 screws from the bottom part of the camera.
  2. Panasonic Lumix DMC-G5 Motherboard Replacement: adım 2, 2 resimden 1. Panasonic Lumix DMC-G5 Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove two JIS #000 screws from both sides of the camera.
  3. Panasonic Lumix DMC-G5 Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove two JIS #000 screws under the viewfinder.
  4. Panasonic Lumix DMC-G5 Motherboard Replacement: adım 4, 2 resimden 1. Panasonic Lumix DMC-G5 Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the viewfinder lid.
    • Then, remove the two JIS #000 screws on the viewfinder.
  5. Panasonic Lumix DMC-G5 Motherboard Replacement: adım 5, 3 resimden 1. Panasonic Lumix DMC-G5 Motherboard Replacement: adım 5, 3 resimden 2. Panasonic Lumix DMC-G5 Motherboard Replacement: adım 5, 3 resimden 3.
    • Gently remove the back panel from the camera.
    • Unclip the ribbon cable from the motherboard using Wide Plastic Opening Tools and pull the cable gently.
  6. Panasonic Lumix DMC-G5 Motherboard Replacement, Motherboard: adım 6, 1 resimden 1.
    • Remove the JIS #000 screws on the motherboard.
  7. Panasonic Lumix DMC-G5 Motherboard Replacement: adım 7, 2 resimden 1. Panasonic Lumix DMC-G5 Motherboard Replacement: adım 7, 2 resimden 2.
    • Unclip the ribbon cable using the Wide Plastic Opening Tool on the motherboard.
    • Gently pull out the cable.
  8. Panasonic Lumix DMC-G5 Motherboard Replacement: adım 8, 1 resimden 1.
    • Pull out the motherboard from the camera.
Sonuç
Khairul Samsudin
412 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G4, Harley Summer 2019 IUPUI, Team S1-G4, Harley Summer 2019 üyesi
IUPUI-HARLEY-SU19S1G4
3 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Dear Khairul Samsudin - this is great, thank you so much.
Can I ask about another classic repair for the Lumix G5?
As with many lumix cameras, the rear thumbwheel on the Lumix G5 is a weak point and frequently fails - usually the “push in” movement that should change functions failes in the “pushed in” position.
Plese can you see if you can create a “fix” for this? It classically fails at about year 2-3, when the camera is out of warranty and the repairs cost from Panasonic is more than a secondhand G5 on eBay will cost!
Best wishes - Paul in the UK
Paul C - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 1,565
